Bulb position failure warning light
2008 volvo S80- I keep getting this message recently, all the lights work and everything looks ok. Does anyone know why this warning light/text comes on every once in awhile? Also, my driver's door window made a popping sound when I put it down... Now it won't go up and down correctly. When I put it down, it falls forward and ends with the top left corner of the window making a peak. I took the door panel off and everything looks okay. Is it a motor? The window is still connected to the riser bars.
I can comment on the "bulb position failure" light... have you checked to see if all of the bulb connectors are working correctly? Mine had dipped a little bit on the front headlight and had burnt through the connector, all I had to do was strip it down to the wire and connect a new one. Hope that helps...
