'01 S-80 Timing belt moving off pulleys
Old May 12, 2011 | 11:05 AM
patarack's Avatar
Default '01 S-80 Timing belt moving off pulleys
Help! I replaced belt, tensioner, and water pump 1K miles ago and the timing belt suddenly has moved 3/4 inch off center pushing serpentine off. I shut down as belt is hanging on by 1/4 inch. WHY? Repair?
Old May 12, 2011 | 12:23 PM
bw77's Avatar
Is the crankshaft balancer pulley tight?
Old May 12, 2011 | 04:59 PM
patarack's Avatar
I believe so. The water pump gear seems too far "out" to allow belt to seat against its inner most (closest to the block) and slanted gear face though.
Old May 12, 2011 | 08:43 PM
Double check to make sure the water pump bolts are tight & torqued. They probrobly are or you would have a leak. Post a few pics please. Can't imagine the water pump shaft bent or coming out?
Old May 12, 2011 | 11:00 PM
gdog's Avatar
Where did you get the parts from? Sounds like a quality issue..
Old May 13, 2011 | 01:07 AM
Typhoon's Avatar
This can only be a few things. I will assume it's sudden and was aligned well when the job was done.
A damaged or loose pulley or pulley bearing and sometimes an internal cord on a belt can let go. It happens, manufacture a million of something and you can get a bad one. Sometimes a washer can be left off behind a pulley or a spacer missed. I've done it.
Old May 13, 2011 | 07:25 AM
ed7's Avatar
ed7
You didn't mention the idler.
Ed
Goodyear1
Aug 16, 2022 02:25 PM
ABVO850
Aug 23, 2012 07:38 PM
ABVO850
Aug 18, 2012 05:24 PM
jikispqr
Apr 11, 2009 02:20 AM
supanda850
Mar 30, 2007 11:34 AM
