Go Back   Volvo Forums - Volvo Enthusiasts Forum > Volvo Vehicles > Volvo S80
Sign in using an external account
Register Forgot Password?
Search
Welcome to Volvo Forums!
Welcome to Volvo Forums,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Volvo Forums today!
LinkBack Thread Tools Search this Thread
Old 01-26-2008, 02:33 PM
Default cam timing to gears
99 s80 t6,2.8replaced timing belt and cam seals(leaking)has varible timing,the exhust cam turned when l loosened the bolt,dont have the volvo alignment tool,with the marks aligned,are the slots on the end of the cams where you would install the alignment tool,straight across with the tool installed or pointed at angle toward the center like it show for head insallation?thanks for any help.
__________________
trailrunner
Old 01-26-2008, 03:09 PM
Default RE: cam timing to gears
Usually it is straight across.
But did you mark the VVt pulley before removing it?
If not you will need to somehow lock the cams and go through a special presidure to get the VVT pulley set right.
__________________
1987 Ford mustang LX Coupe 5.0
1995 Yellow T5-RM running
1996 850 turbo
1994 N/A 5-speed wagon Purple (daughters)
Old 01-26-2008, 04:46 PM
befor l took it apart l lined the timing marks up on the pulleys,l have those lined up now,and the exhust center bolt loose,to adjust,the rear of the cams,the slots are a slightly downward angle to the center,lpulled the plug out of the block and went thru the precedure to make it is at tdc,so with all the should l turn the cams slightly to make the slots line up straight across to each other?thanks
__________________
trailrunner
Old 01-26-2008, 05:50 PM
You should have lined the mark up before removing the belt first and marked.
Then you should have removed the belt and turned the pulley foward and marked it.
Then you should have turned it back and marked it.
The pulley has to be set in a certain position. Some need to be loaded and others just need to be set in a certain position. It all depends on which Cam the VVT pulley is on.
If needs be I can try to post the Volvo precidure so you can try it.
__________________
1996 850 turbo
Old 01-27-2008, 09:48 AM
the pulley is on the exhust cam,had all the marks lined before l took the belt off,as soon as l broke the retainer bolt loose for the vvt pulley it moved,not sure which direction,the intake cam seems like it stayed where it was.thanks
__________________
trailrunner
Old 01-27-2008, 09:55 AM
Yes but did you make 3 marks on the Cam cover for the VVT pulley?
If not you WILL need to lock the cams and do the full precidure.
The pulley when locked down moves about3 to 4 teethof a turn or a little less each way.
__________________
1996 850 turbo
Old 01-28-2008, 08:01 AM
so the pulley need to be centered in its traval,with the slots straight accross.
__________________
trailrunner
Old 01-28-2008, 05:57 PM
I will have to check for sure. I forget it the Exhaust is the spring loaded one or the one that moves free.
I think it is the spring loaded if it is then no it needs to be turned almost all the way foward. It should stop like 1/16 of an inch after the timing mark. Then when you install the belt the mark lines up.
__________________
1996 850 turbo
Old 02-03-2008, 11:50 AM
l bouhgt the cam tool,have it installed with the cams alighn,on the vvt gear be fore you install the timing belt do turn the vvt clockwise till it starts to become under tension or at the start of it?thanks
__________________
trailrunner
Old 02-03-2008, 02:10 PM
I believe the Exhaust VVT pulley should have the tension and be fully at the position to the right just after the timing mark. Like half a tooth past the mark to the right when you look from the front.
__________________
1996 850 turbo
Tags
50, adjusting, c70, cam, cover, instalation, intake, mustang, reinstall, s60, set, timing, volvo, vvt, xc90
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
Secure Backup
