cam timing to gears
cam timing to gears
99 s80 t6,2.8replaced timing belt and cam seals(leaking)has varible timing,the exhust cam turned when l loosened the bolt,dont have the volvo alignment tool,with the marks aligned,are the slots on the end of the cams where you would install the alignment tool,straight across with the tool installed or pointed at angle toward the center like it show for head insallation?thanks for any help.
RE: cam timing to gears
befor l took it apart l lined the timing marks up on the pulleys,l have those lined up now,and the exhust center bolt loose,to adjust,the rear of the cams,the slots are a slightly downward angle to the center,lpulled the plug out of the block and went thru the precedure to make it is at tdc,so with all the should l turn the cams slightly to make the slots line up straight across to each other?thanks
You should have lined the mark up before removing the belt first and marked.
Then you should have removed the belt and turned the pulley foward and marked it.
Then you should have turned it back and marked it.
The pulley has to be set in a certain position. Some need to be loaded and others just need to be set in a certain position. It all depends on which Cam the VVT pulley is on.
If needs be I can try to post the Volvo precidure so you can try it.
I will have to check for sure. I forget it the Exhaust is the spring loaded one or the one that moves free.
I think it is the spring loaded if it is then no it needs to be turned almost all the way foward. It should stop like 1/16 of an inch after the timing mark. Then when you install the belt the mark lines up.
DO YOU HOLD THE PULLEYUNDER TENSION TO THE END OF THE TRAVEL AND THAN INSTALL THE TIMING BELT,WHERE THE GEAR BOLTS TO THE VVT IS SLOTTED,WHEN TIMING MARKS ARE LINED UP,ARE THE THREE BOLTS CLEAR IN THE COUNTER CLOCK WISE POSITION IN THE SLOTS?THANKS FOR ALL YOUR HELP.
spoke to soon,ran fine at first than started loping,can you get the cam sensor ring out,l lined the notches up,cam lock tool lines rt up,crank lines up and went thhru the precedure for vvt,there is a recall on the electronic throttle,could this be doing it ?thanks again.
when l first put the timing belt on,befor l got the cam tool,l turned it over by hand 2-3 turns,no resistant like it would if it were hitting the valves,could it have tweak a valve?l will get it scanned today an see what it says,somtimes it smoothes out and than starts a loping spell,put you in mind like somthing still out of time,does the vvt play a role in the timing like that?
#18
#20
