Mass Air Flow Sensor Replaced
Old 04-09-2009, 07:38 PM
reidjw's Avatar
Default Mass Air Flow Sensor Replaced
Tech, 01 non-turbo S80, I took a swag and replaced the MAF Sensor once I got the check engine. About a month ago a cleaning took care of the rough idle. Eventually returned so I replaced it. Problem is it is still idling rough and the check ehgine light did not reset it. Question is, will it on it's own or does it take a reset at the dealer?
Old 04-10-2009, 12:35 PM
diehardgator1's Avatar
I got auto zone to reset mine. If still running rough have you checked your coil packs? I have an 01 S80 non turbo my coil packs started going out at about 95,000 miles. To save yourself a lot of grief go ahead and replace all 6 of them at the same time as mine would go out about 4 weeks apart finally replaced the last 3 at one time and solved the problem. Replaced my MAF sensor but never really idled rough with a bad MAF but those coil packs will sure run rough at idle Seem to go away with some speed
Old 04-10-2009, 01:23 PM
jmc's Avatar
jmc
jmc is offline
I am watching your post with interest. Same car, same year, same CEL light....cleaned the MAF sensor, light still comes on.....car runs fine. Exhaust system checked for leaks...OK.
I have heard that several drive/stop cycles can make the light disappear (assuming that the MAF sensor was throwing the codes)....Before I replace that part (having cleaned) I plan to erase the code and do several cycles.
Frustrating isn't it ?
Old 04-10-2009, 11:45 PM
Best is to just have the codes cleared.
Old 04-15-2009, 01:51 PM
reidjw's Avatar
As it turned out there was in fact a bad coil, No#3. Dollars restricted me to only replacing the one for now and having the check engine lamp reset. Once I pay off the Fed (15 Apr). I'll get the others. Do you know if a special tool is required to replace the coils and just where are they located?
Old 04-15-2009, 07:20 PM
You need a torxes 30 to remove the top black cover and you will see the coils. A 10MM bolt holds them in.
cla6665
01-20-2008 12:56 PM
jerryman
10-28-2006 07:35 PM
volvogirl850
09-23-2006 03:27 AM
reg
01-01-2006 11:41 PM
floryed
04-14-2005 10:51 AM
Quick Reply: Mass Air Flow Sensor Replaced
