Check engine light - code P2407
Old 05-19-2010, 09:39 AM
vincenzo's Avatar
Default Check engine light - code P2407
Our 2004 S80 had its check engine light come on.
The code that is produced is
P2407
EVAP system leak
Detect pump sens CKT
Intermittant
Any suggestions what I should look at to find the cause?
Thanks
Old 05-19-2010, 07:14 PM
Has the gas cap been left loose lately?
Old 05-20-2010, 06:42 AM
vincenzo's Avatar
No, and we've put gas in it a few times since this has started.
Old 05-20-2010, 08:04 AM
jdp6000's Avatar
P2407
EVAP system leak
Intermittant
Thanks
I get that code on my XC70. I was told by the dealer its the evap canister solenoid or the hose that goes to it. Most likely the hose. It gets hard and brittle and cracks. Its a pain to get to on the XC70. About $160 to fix the hose and $400 is its the solenoid. This is a vent system from the gas tank. It routes vapor to the canister. Its all under the car.
I tried changing the gas cap but it did not work. Their is a rubber gasket that breaks on that too. So you can try the cap first.
Jim
Old 05-21-2010, 07:38 AM
vincenzo's Avatar
OK thanks. I put a new cap on it yesterday. The light is still on today, not sure how long it would take for the light to go out if that was the issue.
Old 05-26-2010, 07:39 AM
vincenzo's Avatar
The light has gone out after a few days. Seems like the cap may have been it.
tngreg
09-05-2022 07:27 PM
doublegranch
12-15-2008 01:25 AM
ErnstlS90
10-23-2008 08:37 AM
Volvo850GLTOwner
04-13-2007 09:28 PM
metz99
06-28-2006 12:48 AM
Quick Reply: Check engine light - code P2407
