Special tool for S80 front shock install?
Old 03-07-2009, 01:41 PM
sonicnofadz's Avatar
Default Special tool for S80 front shock install?
I have the front shock off the car and I do have spring compressors. I have already removed the top nut and top shock mount. However when trying to remove the top spring perch, I have found it to be impossible. There is this "X" shaped nut that is threaded onto the shock shaft, and I lack any type of wrench that can freaking grip the thing enough. How is this X shaped thing supposed to be removed? Does it require a special tool? Any suggestions would be greatly appreciated. Thanks!
Old 03-07-2009, 06:30 PM
yank50's Avatar
Smile
check IPD.com under shocks and suspension or SPX.com for Volvo specality tools, Just bought a special wrench to take the crank nut off with from SPX. Reasonable price for what I got.
Old 03-08-2009, 10:05 AM
You can take a big socket and cut it. I made a tool then use an impact to loosen it.
Here is a pic of one of them I made.
Attached Thumbnails Special tool for S80 front shock install?-picture-038.jpg   Special tool for S80 front shock install?-picture-037.jpg
Old 03-13-2009, 10:13 PM
drewtiss's Avatar
Originally Posted by sonicnofadz
I have the front shock off the car and I do have spring compressors. I have already removed the top nut and top acura shock mount. However when trying to remove the top spring perch, I have found it to be impossible. There is this "X" shaped nut that is threaded onto the shock shaft, and I lack any type of wrench that can freaking grip the thing enough. How is this X shaped thing supposed to be removed? Does it require a special tool? Any suggestions would be greatly appreciated. Thanks!
Were you able to manage to remove that X shaped nut? My friend use to complain this at the shop last week.
tech
03-25-2014 09:11 AM
mountain lion
10-01-2012 04:42 AM
scotjack
04-26-2009 07:49 PM
tech
05-05-2008 06:47 PM
BillA
01-23-2008 06:27 PM
Quick Reply: Special tool for S80 front shock install?
