Code p0300 Random miss
Old Jan 17, 2009 | 02:21 PM
sj6700's Avatar
Default Code p0300 Random miss
I have a 2000 S80, My wife started out with it the other morning and it was running rough, by the time she got home with it it would hardly run. I pulled the codes and got code p0300, p0100, and p0101, I replaced the MAF sensor, the plugs and 1 ignitition coil the plug for cylinder 4 looked fouled, I also cleaned the throttle body. The car runs good driving down the road but has a rough idle setting still, the lights also pulsate what am I missing?
Old Jan 17, 2009 | 07:54 PM
Default RE: Code p0300 Random miss
Are the coils cracked?
Old Jan 17, 2009 | 08:01 PM
sj6700's Avatar
No I've checked the coils for cracks.
Old Jan 17, 2009 | 08:14 PM
Maybe one of the plugs are bad or a coil could still be bad.
Old Jan 17, 2009 | 08:22 PM
sj6700's Avatar
I'm picking up 2 more coils in the morning.
Old Jan 17, 2009 | 08:23 PM
Hopefully that will fix it.
Old Jan 18, 2009 | 10:04 AM
sj6700's Avatar
I changed out 2 more of the coils took it on a 20 min. test drive it ran great no problems got it home let it idle in the garage no problems, shut it off started it right back up and it started to idle rough and is doing the same thing it was before I changed the coils. Could this be a fuel issue?
Old Jan 18, 2009 | 01:30 PM
Possible but I doubt it.
Same code and only that code?
Old Jan 18, 2009 | 02:45 PM
sj6700's Avatar
The car has been setting since 11:00 this morning, I just started it and it is running smooth if I take for a test drive turn it off and restart it, it will idle rough? I just rechecked the codes and now I have code p0011, and code p0300.
Old Jan 18, 2009 | 03:42 PM
Was the timing belt recently done?
Old Jan 18, 2009 | 04:19 PM
sj6700's Avatar
I put a new belt on 16 months ago.
Old Jan 18, 2009 | 04:41 PM
OK then maybe the VVT reset valve on the top of the cam cover is bad.
Mahusay3g
Mar 4, 2015 09:36 AM
bigsparky
Feb 19, 2015 06:36 AM
petmbro
Mar 17, 2013 12:50 AM
jeffreydoctor
Feb 20, 2010 02:18 PM
fritzlovesmary
Dec 6, 2007 09:33 AM
