Headlight
Old 12-03-2006, 02:53 AM
althej's Avatar
Default Headlight
After driving on the freeway today, my headlight cracked because of a rock. There is a big hole in the lens and it spider webbed on me. Has anyone changed the headlight piece, or the lense it self. what problems did you encouter, did you remove the grill, or the bumper. any other things had to be removed? where can i get a headlight that will fit perfectly, or should i just get it from the dealer, any past experience with this guys? help me out please
Old 12-03-2006, 12:08 PM
Default RE: Headlight
I have heard of alot of people buying the Glass off of E-bay.
You will have to remove or loosen the front bumper and slide it out to get the Headlight out.
Old 12-05-2006, 02:35 AM
gordon368's Avatar
My headlight filled with some water lol, what do i do, It freezes at night and Melts during the day.....(too cold to evaporate)
It happened a few days ago, The Errors message comes up, bulb position out of place....... but the headlights work fine...
Is there a crack or soemthing in my headlight?
Old 12-05-2006, 08:24 PM
Usually condensation means Air leak.
Old 12-05-2006, 08:32 PM
gordon368's Avatar
haha ... i cant seem to find it...>< lol
Old 12-05-2006, 08:44 PM
You won't if the gasket between the glass and housing is cracked air will get in there as well.
Not to sure what to tell you because you have to remove/loosen the front bumper to get the light out.
Old 12-05-2006, 09:17 PM
gordon368's Avatar
Have you seen these things covered under warranty?-for the reason you just told me
Old 12-06-2006, 08:29 PM
Factory warranty yes.
Extended no but it would be worth it to ask.
Old 12-07-2006, 12:28 AM
gordon368's Avatar
Does it matter the coverage type i got? I have comprehensive coverage
Old 12-07-2006, 08:39 PM
Im not sure you would have to call them and see if it is covered.
Old 12-11-2006, 11:51 PM
gordon368's Avatar
If the headlight is still working why does the error message come up for it? is it kno that there is water in my headlight lol? shuts off after a minute or so..
Old 12-12-2006, 12:05 AM
Not sure maybe bad connection.
slynchy
04-04-2016 07:37 AM
danni
09-17-2013 11:56 AM
Peter1234
11-23-2010 01:19 PM
kevinmcgrath
11-24-2004 06:57 PM
scoutdavis
09-22-2004 08:49 PM
Quick Reply: Headlight
