Courtesy light under side view mirror
On my 01 S80 T6, the light under the side view mirror (driver's side) is out. I do not see any exterior access screws to release the lens cover to get to the bulb for replacement. I have found the bulbs to use, only can't get into the housing to change it. How do you get the lens cover off? Thanks Tech.. Richard
RE: Courtesy light under side view mirror
I guess I'd have to tilt the mirror glass all the way up to get access to the bottom peice I need huh? The dealership says it just pops out, but it is in there with some force as I have tried to lightly pry it off.. I'll see what's under the looking glass, so to speak. Thanks again. Let me know if you thyink of anything else.
R
R
Removing the external side glass wing mirror on the door.
You are standing in front looking at the mirror reflective side.
Grab the outer edge (as opposed to the inner)
Pull towards you, so mirror is folding inwards.
Then work its way out.
I don't think you need to remove the mirror to replace the bulb.
You may be able to fold the mirror upwards enough to fit a screwdriver at the bottom of the mirror where you can push on the catch located on the outer edge of the bulb housing to release. You will be using the screwdriver to push on the catch inwards towards the car.
Go figure. A few days after I happen to read this post My wife tells me the Driver side courtesy light is out. Anyone have a common (or industry standard) bulb number for this? The only numbers I have are volvo part numbers 30634737 or 9203539. According to VADIS, this is the only location where these bulbs are used.
ORIGINAL: re100005
