Fuel pump Removal
Old 06-10-2010, 08:45 AM
jdp6000's Avatar
Default Fuel pump Removal
How do you access the fuel pump? I have a gas odor but no gas leak. Its a 2000 S80 T6.
Jim
Old 06-12-2010, 09:02 AM
cabikefreak's Avatar
I know there was a recall for some years to replace the fuel pump. You may want to check on this!
Old 06-13-2010, 12:08 AM
SVTfocusO3's Avatar
Jim
It more than likely is the fuel pump, which is under the rear seat, I am not going into detail if I can help it, but call your dealer and see if your under Recall 220, it is probably covered.
Old 06-13-2010, 07:09 AM
jdp6000's Avatar
Thanks everyone. I will check with the dealer tomorrow. I see postings about the 2001 and up fuel pump recall but nothing on the 2000. It should be the same though.
I will post what i find.
Jim
Old 06-13-2010, 08:29 PM
SVTfocusO3's Avatar
That model year 2000 you may be correct, I would contact them and see what they can do. The recall does not cover 2000, but if you need step-by-step on it, let me know.
Old 06-14-2010, 04:51 PM
jdp6000's Avatar
No warranty up here. How easy is it see the pump? Its under the rear seat right? Does the seat just flip up? I want to see if anything is leaking out.
Jim
Old 06-15-2010, 04:02 PM
SVTfocusO3's Avatar
If it is not an executive, you can just lift the rear seat out, it will be under the right side on an incline, you may have to remove a black bar, you will see a access cover, remove the two visible nuts, then release the right backrest in the trunk, fold it down and you should be able to access the other two and see if its leaking, but if you want to remove the side bolster on the right, releases on the bottom (little tricky), and remove that backrest completely (SRS connector and 14 mm bolt), you will do this anyways to replace it and is easier to access.
Tools needed for backrest removal:
3/8 air impact works best
17 "mm socket 3/8"*
15 " "*
14 " "
10 " "
*may not be needed
Old 06-15-2010, 04:36 PM
jdp6000's Avatar
What is an Executive? Mine is a 2000 Volvo S80 T6.
Do yo mean this one....this an executive...its not what I have...http://www.volvoclub.org.uk/current/...ochure2000.pdf
Jim
If it is not an executive, you can just lift the rear seat out, it will be under the right side on an incline, you may have to remove a black bar, you will see a access cover, remove the two visible nuts, then release the right backrest in the trunk, fold it down and you should be able to access the other two and see if its leaking, but if you want to remove the side bolster on the right, releases on the bottom (little tricky), and remove that backrest completely, you will do this anyways to replace it and is easier to access.
17 "mm socket 3/8"*
15 " "*
14 " "
10 " "
*may not be needed
Old 06-15-2010, 04:48 PM
SVTfocusO3's Avatar
See the back seat???? Difficult!
I believe the executive is distinguished by the badge near the rear side window.
Oh and one more thing, there is an SRS connector on the rear backrest, do not turn the car on if this is removed.
Old 06-15-2010, 05:25 PM
jdp6000's Avatar
By right side do you mean driver side or passenger side?
Jim
Jim
Old 06-15-2010, 09:33 PM
SVTfocusO3's Avatar
As if you were driving, passenger.
spidersilva
08-17-2011 07:23 PM
s_moneh
11-30-2009 02:03 PM
moonraker
05-08-2007 10:16 PM
pirate240
08-02-2006 11:21 AM
Quick Reply: Fuel pump Removal
