Help with oil drain pan
I have tried to remove my oil drain pan with no luck. I have gotten all the bolts out, have removed 2 motor mounts(due to breakage) and have loosened the subframe bolts. I have jacked up the transmission as well. The pan is loose but I cannot get it out from the engine. It seems like there are lips on the edges that are catching? Please help!!!!!!
jbarnes
06-12-2013 11:46 AM
thoroughbred
01-15-2008 10:19 AM
