How do I press in a new balljoint?
Old 02-05-2010, 01:54 AM
poor_red_neck's Avatar
Default How do I press in a new balljoint?
So I'm replacing my control arm and bushings as well as ball joints.
I got the old ball joint out with nothing but a small hammer and a flat head screwdriver. However I'm having a hard time getting the new balljoints in. I didn't take the hub off and only have the car on jack stands. Not much room to swing a hammer.
Any tips?
Old 02-05-2010, 09:38 PM
I use the screws and try to keep the balljoint level. But I use a punch and tap it in some then screw the screw in a little at a time till it is seated.
I just did one today at work.
Old 03-06-2010, 02:15 AM
Magnum PI's Avatar
Shop quoted me over $500 to do the front. Thinking about trying this myself as the front end sounds like a bucket of bolts. Is it do-able in the home garage without special tools?
Old 03-06-2010, 09:27 PM
Yes it is.
Old 04-27-2010, 07:14 PM
trebuchet5684's Avatar
Angry
I'm ready to start throwing hammers here, Tech. I think I damaged that tiny little seal on the inside "flange" if you can even call it that. This job is frickin' impossible. Any idea where to get the &%&*{$ recommended tools?
Old 04-27-2010, 07:43 PM
DO you mean the boot on the balljoint?
How bad is it?
Another thing you can try is find a metal pipe that will just go around the boot and hammer on the pipe to tap it in.
Old 04-27-2010, 07:44 PM
Not the boot, the little tiny gasket around the base. Appears to be a seperate piece but hard to tell.
There's nothing for the pipe to rest against on the inside.
Old 04-27-2010, 07:47 PM
You slide the pipe right over the balljoint shaft and it rests where the bolts go through the balljoint into the hub.
Old 04-27-2010, 07:51 PM
I rented a traditional ball joint press that has parts similar to what you're talking about. Problem is that when you tap it, the ball joint goes in leaning to the outside because there's no lip on the inside of the part so all the pressure goes on the outside, front and back where there is a place to push against.
I'm trying to upload a photo ... let's see how this goes.
Last edited by trebuchet5684; 04-27-2010 at 08:00 PM. Reason: additional information
Old 04-27-2010, 08:04 PM
the near side is the side that I cannot seem to get to go in.
Old 04-27-2010, 08:07 PM
As long as it presses on the balljoint you can hit the opposite end of the pipe to straighten it.
Or do like I said originally said. Use the screws to put pressure on the balljoint and tap the balljoint in and keep tightening the screws at the same time. Hit the balljoint towards the inside like right next to the screws.
Old 04-27-2010, 08:12 PM
I'll keep at it. Thanks.
Old 04-27-2010, 08:14 PM
I wish I had an easier way for you. But I do not. If the pipe rests just inside the bolt holes and you hit it straight it should go.
Old 04-28-2010, 12:29 AM
Default I used a blow torch
I hope I am not out of line and of course you will want to wait for a reply from the techs. At the recommend of Senior Member "Typhoon" I used a propane blow torch to heat up the metal and the ball joint squeezed right in as I gradually tightened the bolts down. Be careful not to heat up the rubber. I too went through all the same frustrations as was explained here and I even damaged the rubber with the sleeve I had been hammering with. I too had rented a special tool to no avail.
Don
Old 04-28-2010, 10:49 AM
Beachbum's Avatar
Default Ball Joint replacement - S80
For what it's worth...
I went to Home Depot and bought a 2" (ID) x 3" long pipe nipple. This fits perfectly around the ball joint. I just lined up the bolt holes by eye, tapped it in a little to get it started straight, and used the pipe nipple and a hammer to seat it all the way (with the steering knuckle resting on a block of wood).
I did remove the steering knuckle from the car, however. I agree it would be hard to do this with the knuckle still on the car.
Hope this helps.
Old 04-28-2010, 09:04 PM
Thanks all. I did the same on Tech's recommendation. $7.50 at Lowe's and they both went in slick as snot. (That's 2" ID x 3" long plus a cap to beat on.) A good dose of axle grease helped too. I did not have to remove either knuckle from the car. In case this helps anyone else, pics are below.
Attached Thumbnails How do I press in a new balljoint?-img00027.jpg   How do I press in a new balljoint?-img00028.jpg
  #17
Old 02-10-2016, 07:47 PM
rohde1's Avatar
How are you guys getting the old ball joint out? Is there access on the hub to drive the ball joint down?
  #18
Old 02-11-2016, 08:04 AM
strelnik's Avatar
Great advice!
Does anyone know if this will work on the Volvo 960, in case I have to do ball joints?
Thanks!
  #19
Old 04-21-2019, 07:14 PM
cgerrells's Avatar
Old thread, but I'll have to give this a shot tomorrow, I have spent the last 2 days trying to seat my drivers ball joint. Even tried driving it around to see if it would pop in, these things are a pita.
  #20
Old 04-22-2019, 04:50 AM
1967 Tempest's Avatar
I have tried all kinds of things on ball joints. I bought this
https://www.amazon.com/gp/product/B00061SGJ0/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00061SGJ0/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
to do the ball joins on this.
Super easy. Just use a lot of WD-40 on the threads of the tool. You almost dont need an impact gun!!
0.02$$ Hope that helps.
kevin crisp
07-13-2022 05:54 AM
greg21
04-09-2011 06:29 PM
schigara
12-03-2009 08:48 AM
KeithS60&V70T5
11-14-2009 12:24 PM
volvobacon
10-11-2005 09:11 PM
Quick Reply: How do I press in a new balljoint?
