Left Side mirror and window
Hello guys!
Maybe someone knows what caused my problem and how to fix it.
My left side mirror doesn't work from the dash BUT it works perfectly when you use the driver seat adjustment buttons ( the mirror adjusts automatically when you press the memory button the way it was some when saved )
The right works perfectly.
And the left side passenger window works fine if you open/close it with the button next to it, but it can't be opened from the driver's dash but it can be closed from there.
And one more, why does radio always SEARCH for stations even if it is saved?
Thank you !!
Thank you !!
Hi I am going threw the same problem but mine is the pass side and driver seat. So far the only thing I found was my pass side window switch is no good. So you should check the driver side window switch. And if you buy one it will not work till you program it. But I will let you know more when I found out on the one I having problem with.
cubscout
08-18-2014 04:45 PM
TATAIECU
03-29-2014 08:10 PM
cshields
05-23-2010 01:13 PM
