my thermostat replacement on my 2003 s80 t6 2.9
code po128 talked to the dealer and they wanted 685 bucks to install my stat,so I replaced it my self,if you want to replace your water temp sensor you need to remove the whole stat housing and you need to remove a cam guzmo to remove a bolt and a plastic wire guard.Make sure you get both gaskets for the housing.
rspi
06-28-2013 10:33 PM
