Is it normal for bad ABS wheel speed sensor to show wear marks?
Old 10-06-2016, 05:14 PM
e.mence440's Avatar
Banned
Default Is it normal for bad ABS wheel speed sensor to show wear marks?
After scanning my ABS system , and found a code for the front drivers side
wheel speed sensor , I decided to pull the sensor to inspect....
After removing the sensor it was obvious that it was bad just by the
sight of it ,(I should've taken a picture of it)
My question is , is it normal for the sensor to have this much wear?
I own a 04 Volvo S80 T6 Premier DSTC option as well if that matter's
I ordered a new one and don't want to break a new one if I'm
missing something...
any help on this matter would be appreciated ...
Thank You.
Old 10-07-2016, 03:12 PM
e.mence440's Avatar
Banned
Default Replaced ABS speed sensor ....
Well I guess everything is in working order ,guessing that there was
a wheel bearing issue at one time, because everything feels tight
and secure when I tried to check for play ,,
here is the pic of the old sensor (must be original )Is it normal for bad ABS wheel speed sensor to show wear marks?-img_0132%5B1%5D.jpg
Is it normal for bad ABS wheel speed sensor to show wear marks?-img_0133%5B1%5D.jpg
bradpeterson2
04-26-2017 08:50 PM
Blkwidow
09-21-2013 02:34 AM
michaelm
01-06-2013 08:06 AM
j2carl
04-24-2011 10:40 PM
blwnkl
04-06-2011 11:20 AM
Quick Reply: Is it normal for bad ABS wheel speed sensor to show wear marks?
