OBD II error codes p1132 and p0140
Old 10-01-2007, 04:04 PM
Jamez2u's Avatar
Default OBD II error codes p1132 and p0140
I got an auto scanner that reads and erases codes because I have a check engine light on. The first code I got was P1132 Manufactuer Contrl. Fuel Air Metering
second code is P0140 (Bank 1 Sensor 2) 02 sensor CKT no activity.
any idea what either of these mean?
I am thinkin one is an o2 sensor as I took this 99 vovlvo with 195k miles on it to a vovlo repair shop and he said that I need to replace both catalytic converters and all four O2 sensors wich is going to cost more than 4k in parts alone according to him.
Thanks in advance for you help.
BTW the car runs great except for the check engine light and the srs airbag message.
Old 10-01-2007, 06:34 PM
Default RE: OBD II error codes p1132 and p0140
The 1132 I believe is a bad mass flow sensor or a vaccum leak which would also cause the O2 light to come on. But you might still have a bad O2 though.
snowisgr8
2001-2013 model year V70
05-10-2015 12:49 PM
clutch33
08-17-2014 03:45 PM
creekbat
03-05-2013 06:45 PM
volvojunkie
03-15-2009 12:35 PM
Quick Reply: OBD II error codes p1132 and p0140
