oil filter cartirdge 'socket' recommendations please
For my new 2016 s80...I want to buy a filter cap socket that fit over the oil filter cartridge....
This one claims it will fit but...I've been reading that the s80 changed in 2014 (2015?) so I am uncertain if this will work....
or this one - which is more expensive...
I know there is a difference between something that 'will work' and something that '*really* works", so I want the one that *really* works.
Amazon.com: Assenmacher Specialty Tools V 410 Oil Filter Housing Wrench for BMW and Volvo: Everything Else
First one fits the size of filter, if you want to know if it would *really* work then start with finding the size you need. Then purchase the correct size.
64mm, 86mm and 88mm
Second one is only an 86mm you get no choice there.
Just measure and get the one that fits based on that. You will be fine unless you cant use a tape. You may be able to find sizes online somewhere of the filter I don't know.
64mm, 86mm and 88mm
Andrew Fritz
01-10-2016 06:44 PM
