outside air temp sensor
I am not 100% on removing the door panel, but you can try otherwise.
Ignition off.
Remove the key.
Note! The key must be removed to ensure that the ignition is not switched on by mistake.
Note! After the key has been removed: Wait 1 minute before starting work.
Pull the upper edge of the panel inward.
Disconnect the connector.
Install:
In reverse order.
Removing the door mirror
Fold the mirror glass forwards and inwards as illustrated.
Grasp and pull the mirror glass lengthways until it releases.
Work the glass out.
Disconnect the terminal pins from the mirror glass.
Removing electric motor
Note! Note the positions of the connectors.
InstallationInstall the electric motor
Install the terminal pins.
Fold out the mirror mounting on the motor.
Hook the mirror glass into the inner mounting.
Press the mirror glass into place.
Installing the door mirror
Ignition off.
Remove the key.
- Remove:
the side piece for the door mirror
the surround for the inner door opener
the cover in the inner door handle
the screw by the inner door handle - the press clips.
Install:
In reverse order.
- Remove:
the cover - the door panel. See Panel, front side door, replacing (-2003) or Panel front side door, replacing (2004-).
- Remove:
a nut - the door mirror.
Work the glass out.
- Remove:
the mirror glass - three screws.
- Install:
the connectors
the three screws - the mirror glass.
- Install:
the door mirror
the nut
the connector
the door panel. See Panel, front side door, replacing (-2003) or Panel front side door, replacing (2004-) - the cover.
SVT, I could use those instructions or pictures. My outside temp sensor has stopped working. Dealer tells me on a 2003 XC70 there is one in each mirror. I suspect i have to pull off the mirror to get at the sensor somewhere in behind. My mirror cases are solid one piece....so to get at guts it must be by first removing the mirror.
Jim
Jim
Ignition off.
Remove the key.
Install:
In reverse order.
Work the glass out.
Ignition off.
Remove the key.
- Remove:
Install:
In reverse order.
- Remove:
- Remove:
Work the glass out.
- Remove:
- Install:
the connectors
- Install:
the door mirror
the nut
the connector
