P0014 code, what to look for
I have a P0014 code which is "B" Camshaft Position - Timing Over-Advanced or System Performance(Bank 1).
Looking for some tips on what to look at first. The main complaint is that I have a rough idle.
The timing belt was replaced at the dealership last month and it had a rough idle before that with a CEL on. I'm a little baffled why the dealership didn't check/fix this then.
Anyway, help is appreciated.
To check that I would need to pull the timing belt off?
The dealership did say to drive it for about a month and if it didn't clear up they would try to clean the screen. I'm assuming they meant the CVVT solenoid screen?
