Go Back   Volvo Forums - Volvo Enthusiasts Forum > Volvo Vehicles > Volvo S80
Sign in using an external account
Register Forgot Password?
Search
Welcome to Volvo Forums!
Welcome to Volvo Forums,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Volvo Forums today!
LinkBack Thread Tools Search this Thread
Old 08-31-2010, 07:24 PM
Default P0442 Small Evap Leak
So this minor code shows me the check engine sign, but doesnt show a meesage in the window to the left of the speedo.
i say this code is minor because my performance and mileage is still the same
From the quick reading i have done this code has something do to with the Evap recirculation system, where fuel vapours are routed via a valve from from the manifold (?) to some vapour storage box and back to the intake
Just wondering if anyone has any clues on this for me to check out?
CAR: 99 S80 T6, all maintenance up to date, no recent work done so this code just kinda came out of nowhere...thanks
__________________
1999 Volvo S80 T6 Bought @192KM...now @226KM and counting the high priced maintenance miles ;-)
Old 08-31-2010, 07:52 PM
P0442
Possible Source
leaking fuel tank, filler pipe, fuel tank filler cap, EVAP canister, EVAP canister shut-off valve or lines between these components
Check the gas cap and gasket 1st.
Old 08-31-2010, 08:08 PM
I looked at the lines between the cooling fan and the intake, all seem connected, i could not really find anything under the car, but its hard to get in there without jacking it up
how do i check the gas cap ? it clicks when i close it, and what gasket are you referring to ?
__________________
Old 08-31-2010, 09:59 PM
koziolek's Avatar
Im having the same problem
cant find solution
any more suggestion?
__________________
Old 09-01-2010, 07:13 AM
There is a black gasket in the gas cap that you can see cracking. You may be eligible for the EMS extended warranty, ecm upgrade at no charge, call dealer.
Old 09-01-2010, 08:47 PM
koziolek's Avatar
gasket is fine
any other ideas?
__________________
Old 09-01-2010, 09:00 PM
warranty i belive is only 10 years 100,000 mile ext. warranty on that.
but i may be wrong. if u have a major leak its most likely tha gas cap.
theres many diff. things it could be a sticking evap valve a torn hose in the evap system. many little things. u will need to know what codes u have
Old 09-02-2010, 07:23 AM
EMS ?
ECM software upgrade is already done
need2fix: Please look at my original post and title of the thread,. the code and what it means is P0442 Small evap leak, dont think its gas cap cause i dont smell gas around it, but im sure the gasket is cheap so ill buy it on the weekend
im out of ideas...
__________________
Old 09-06-2010, 11:35 PM
well, its not the gas cap
__________________
Tags
2001, 99, code, engine, evap, evaporator, leak, p0442, po442, s80, s80t6, small, t6, v70, volvo, xc70
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
Secure Backup
