P1550 code, any suggestions? - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 10-23-2008, 07:30 AM
Default P1550 code, any suggestions?
car is throwing a P1550 code, speed sensor, idle control etc. I believe all this is pointing back to the abs module which has gone bad. Will having the abs unit rebuilt fix this code?
Old 10-23-2008, 09:08 AM
Default RE: P1550 code, any suggestions?
P1550 is code ECM-510F, vehicle speed signal. I would have it scanned with a volvo scanner before rebuilding the ABS module.There are other things that can trigger this code. It could be a signal too high, too low or lost all together. I don't know what type of scanner you used to pull the code, but you will see much much more with a volvo scanner.
Thread Thread Starter Forum Replies Last Post
1999 s70 - abs/tracs/engine lights - p1550 Pubcha Volvo S70 1 11-26-2014 09:34 PM
ABS light/ ABS Service Light/ P1550 Scott V 2001-2013 model year V70 1 02-08-2014 07:46 PM
Lost? P1550 alfords80 Volvo S80 0 08-31-2009 07:49 PM
Engine Code 113 long term fuel trim. Any suggestions.... preese Volvo 850 6 06-06-2007 10:18 PM
83 242 GT resto, any suggestions oldvolvobrik Volvo 240, 740 & 940 1 11-02-2006 07:21 AM
Tags
07, 1999, 2000, 510f, 740, 99, c70, code, ecm, ecm510f, engine, p1550, s70, s80, v70, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
