position bulb warning
I know there have been some posts about this, but thought I'd check again. Yellow triangle warning light comes on intermittently and display reads position bulb failure.I understand the position bulbs are the ones in the bumper on the 02 s80 t6, but they seem to work, as do the license plate bulbs and the others. Pried them out, banged on them, still getting the message. Is there any way to sdetermine which one is triggering the warning. Thanks
Yup...it happen to me recently...after you greased them all...the warning indicator does not appear again...thanks for the kind input :-)
still getting warning
are there other bulbs that could trigger this? Thanks
Interesting, I didn't know on the older S80's the brake bulb was on top, in the '05/'06 S80, the LED brake lights are under the reverse lights and the Position Bulb/Running Lights and Rear Fog Light (driver side only) are above the reverse lights.
I think I had this warning and could not figure it out till I realized there are TWO license plate lights- and one was burned out. Nice that Volvo has backups for this, and the tail lamps. Could save one getting a ticket!
I also discovered that it uses the same bulb in all four headlamps. So, if your "low beam" bulb burns out and you don't have a spare on hand, you can swap out a high beam bulb for the low and your legal till you get a replacement.
master_pre
10-22-2006 12:29 PM
