Question about Powerchip - pros and cons
Old 03-07-2005, 03:39 PM
Majki's Avatar
Default Question about Powerchip - pros and cons
Hi there,
Has anybody used a Powerchip in their S80s from Powerchip Inc?
What this basically does is your car gets updates of the software in your car’s engine control unit. The benefits are (by Powerchip Inc.)
"more performance, quicker throttle response and better overall drivability. The software is simple and easy to install, can be
reversed to original settings at any time, and comes with a 100% satisfaction guarantee. If your car is covered by a new car
warranty, you needn’t be concerned. Your Powerchip upgrade is totally undetectable by your service dealer (even if it was they
cannot void your warranty because of it). " but they don't say what are the cons.
I would like to know if this kind of modification to ECU can cause easier damage of the engine and other parts (especially turbo unit, seals etc.). How much the engine will last with this kind of modification?
Thanks for the advise,
Majki
Old 03-17-2005, 08:42 AM
Default RE: Question about Powerchip - pros and cons
Hi,
Have heard on some C70's that this would cause some damage to the turbo unit and seals, but only in the longer run. Also from what i've heard, if the car is quite new and has lowq mileage, this should not be a concern. So i'd say if the car's engine is in good overall condition then go for it.
hermi
09-06-2010 01:15 AM
4cfed
01-16-2010 03:55 PM
Hexkraut
10-18-2008 05:09 AM
S70 Owner
03-20-2006 12:35 PM
AaronD81
03-16-2006 11:10 PM
Quick Reply: Question about Powerchip - pros and cons
