Random Multiple Misfire, Fuel Trim System Too Lean, Cylinder 5 & 6 Misfire
Old 06-22-2014, 01:20 PM
divinedavis's Avatar
Default Random Multiple Misfire, Fuel Trim System Too Lean, Cylinder 5 & 6 Misfire
When I try to crank the car it will take long or will not crank until I try it again. It works sometimes when I tap the gas pedal a few times. I get a reduced engine performance if it takes long to start up. These are the only major problems I have with the car. 138,000 miles on it. Volvo S80 2002 2.9L
Old 02-28-2016, 11:15 AM
jaydownsouth's Avatar
Default did you get it fixed ?
I'm having the same codes but I have the twin turbo and it takes a long time to start . I have drained my battery attempting to start it sometimes. Would love to know if you got it fix before I drop mine to Volvo
Old 02-28-2016, 11:33 AM
to the forum jaydownsouth
Have you tried to swap coils from 5&6 with any of the other four to see if the misfire moves ??
Have you inspected the plugs and if so how did they look ??
Any chance you have something causing a vac leak to those cylinders ??
Old 02-28-2016, 06:33 PM
Default Tried it
I purchased all new plugs and coils. I even pulled the fuel rail and turned the key to make sure the fuel injected were spraying fuel cause I knew it couldn't be the coil or plug. I'm sure it's a vacuum leak somewhere but that won't explain the hard start. This is the first Volvo I have worked on and owned
old motor head 393
03-14-2022 08:59 PM
Benjimang
08-28-2015 05:10 PM
crimsonseraph
08-09-2015 10:33 AM
1bluecove
01-07-2011 07:43 AM
Quick Reply: Random Multiple Misfire, Fuel Trim System Too Lean, Cylinder 5 & 6 Misfire
