SPEED SENSOR 99 S80 T6
RE: SPEED SENSOR 99 S80 T6
I just got the ABS Module back today from BBA REMAN and they found no fault on my MODULE. I installed the ABS MODULE back on my car and drove it for about 10miles. All the messages are still there: BRAKE FAILURE STOP ASAP.....etc. Now. This ABS MODULE has been tested by Victor once and found no fault. Tested by BBA REMAN and found fault repaired it and then tested. I return it back to them and tested again no fault. So I'm back to the same problem. Do I have to go to the dealer and get these messages reset. I thought after the ABS MODULE would be repaired they would go away. Can a faulty SPEED SENOR cause these ABS messages and the could be the cause of the TRANSMISSION SER REQ message and a misfire?
Well, they charged me 45.00 for that. Plus I got a oil change Valvoline 10-30 f/ 19.18; washer DP 850 1.00; Filter 9.28; cabin filter 25.95 .... total was 119.48
Tomorrow I might just go to a dealer and see what they can do as far as clearing the messages and lights. I called a Volvo dealership in Irvine, CAand they said they would charge me 128.00 which is a diagnostic cost. They said in order to clear messages and codes they have to set it up like a diagnostic.
#18
