T6 2005 hid beam too high after bulb replacement??
Old 12-06-2016, 04:42 PM
roglesby5's Avatar
Default T6 2005 hid beam too high after bulb replacement??
Replaced both d2r hid bulbs and 1 balast but now beam is way too high and down adjustment is maxed out. Low beam bulb failure still remains but both bulbs come on. Could bulbs be put in upside down, or not inserted far enough into the metal casing?? Any suggestions appreciated..
-R
Old 12-06-2016, 07:56 PM
firebirdparts's Avatar
Bulb location is critical, certainly. They are indexed so that they'll go in only a certain way, and they have to be correct.
On the S70's they are bad to pop out of the adjuster. It's a little ball and socket arrangement. When you push on the reflector sometimes they will just disengage and then it's shining way too high. If this happens, you can probably snap it back in by removing the bulbs to give you a spot to pull.
Sir James
11-07-2012 03:38 AM
RebeccaB
10-03-2011 06:06 PM
2005s60
01-19-2011 01:50 PM
asudan
03-01-2007 02:05 AM
llcoollam
04-24-2006 06:54 PM
Quick Reply: T6 2005 hid beam too high after bulb replacement??
