transmission fluid info - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 06-27-2005, 01:46 AM
Default transmission fluid info
2004 S80. Why is there no owners manual info on how to check the transmission fluid; or am I missing something? Different cars have different procedures. Check when hot or cold? Transmission in neutral or park? Simple stuff like that.
What is the trans fluid check procedure?
Old 06-27-2005, 03:48 AM
Default RE: transmission fluid info
Check it hot and with the car in park.
Old 06-28-2005, 02:30 AM
Thanks.
Old 06-29-2005, 05:14 AM
eli eli is offline
Does the engine have to be running to check it?
Old 06-29-2005, 08:49 PM
Quote:
ORIGINAL: eli
Yes it has to be running to check it properly.
Old 07-24-2005, 02:59 AM
Also, I do not see any trans fluid change info. except for trailer towing at 50K. Is there no normal trans maintenance required? Like, is it perpetual or something. That would be cool, but I doubt it. Do you recommend any normal trans maintenance?
Old 07-24-2005, 04:21 AM
It is supposed to be at like 100,000 miles.
Old 07-24-2005, 01:38 PM
reg reg is offline
Trans oil is inexpensive. I change fluid in all my autos...........both automatic and manual transmissions...........every two years. In my case, that is LESS than 25,000 miles as I am splitting a year's mileage between several automobiles. Brake fluid is also changed, although I do that once a year. I use a MyTvac and "pull" the fluid through. Lastly, I use ATE Super blue Dot 4 brake fluid. If you change the brake fluid often you will never have a brake caliper rebuild...............all the sludge and debris is flushed and along with that you have removed the condensation which gives you the 'soft' pedal as the water begins to boil.
Old 07-24-2005, 05:38 PM
Yeah, I tend to do that also. Re: trans, I have had a couple vehicles that stated 100k change, with more frequent on trailering. But I always follow the heavy duty schedule. 100K just seems a looong way. Just that it is strange there is no trans maintenance info at all!
Old 07-24-2005, 07:03 PM
reg reg is offline
The cost of a rebuilt trans plus the installation far outweigh the minimal cost of the fluid flush. Volvo truly gives minimal information about the maintenance of their vehicles................I think they like to sell parts right after the warranty has expired! On a 70 series, you can't even see the trans dip stick unless you shove the hoses over............. Maybe now that Ford Motor Co. has the controlling interest in Volvo, we might see a better product and a better manual??????
Old 07-24-2005, 11:40 PM
I hope so as well.
Just because I said that they say 100,000 miles doesn't mean you have to wait till then.
You can change it when ever you want.
Old 07-25-2005, 12:11 AM
reg reg is offline
You bet Tech. Your input is invaluable. You are a formally trained Volvo mechanic...................for a lot of us, we opine on what we have experienced over the years. I draw much of my opinions from 47 years of driving and having participated in many driver's schools and SCCA racing. It is now interesting to find that BMW, now that they no longer have a "free" service policy, have gone to "life time fill" in their transmissions and rear ends. Prior to their latest policy fluid changes were one year on brakes, and two years on coolant, trans fluid, and axle. The Roundel and Bimmer still insist on the earlier program and for good reason. By the way, now that you are an independent, is there a web site you can direct us to that has a listing of independent shops in the various states?
Old 07-25-2005, 12:27 AM
Not that I know of if I find one I will let everyone know.
Thread Thread Starter Forum Replies Last Post
Need manual trans info from Converse kit, trade auto trans info? nortons General Volvo Chat 0 02-23-2015 12:14 AM
XC 70 shift Flair / Slip fixed and ATF fluid Info. slipinxc70 2001-2013 model year XC70 1 05-09-2013 09:55 PM
Info on S60 2012 T5 Transmission fluid 426HPSS Volvo S60 & V60 3 12-25-2012 09:58 AM
Power Steering Fluid Info + Flush Info nicolaselias Volvo S80 18 03-24-2011 09:48 PM
Would low transmission fluid cause a transmission service required message to show up icehouse719 Volvo S80 0 11-10-2010 04:31 PM
Tags
2000, 2004, atf, check, checking, fluid, jumps, oil, s40, s80, s80check, transmission, type, v70, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
