vacuum leak?
Old 12-12-2006, 09:48 PM
nick54's Avatar
Default vacuum leak?
I've noticed a whistling noise coming from my car. I'm not really sure what it is, but could it be a vacuum leak? What kind of symptoms would I see if I had a vacuum leak? Thanks!
Old 12-13-2006, 12:08 AM
Default RE: vacuum leak?
Maybe a vaccum leak.
You might not notice anything.
Worse case a check engine light and maybe idle surge.
Is it a turbo or Non?
Old 12-13-2006, 06:25 AM
v70 2.4t's Avatar
Dont mean to be a smart ****...but i may be the turbo, if you have one?... I can sometimes hear mine and other
times not??
V70 2.4t
Old 12-13-2006, 04:10 PM
nick54's Avatar
I do have a turbo. I really only notice the whistling when I'm idling...would the turbo be on when idling? Thanks for the help.
Old 12-13-2006, 08:45 PM
Turbo will not be on Idling.
Try to listen closely to where it is coming from.
Old 12-21-2006, 07:21 AM
Mine has a whistling noise too, but when i took it in recently to get #5 cylinder coil pack inspected due to emissions check, mechanic said whistle was fine, nothing unordinary. My engine runs fine after coil pack fixed. My fuel pump whines something fierce but still running ok. Are you losing performance?
chachouu
03-26-2008 08:43 AM
robnov
10-06-2007 05:03 PM
pc142
10-17-2006 03:37 PM
speedwagon
05-26-2006 12:09 PM
hordezla
04-14-2006 08:59 PM
Quick Reply: vacuum leak?
