Volvo S80 2.0T Oil leak?
Old Sep 2, 2010 | 08:19 AM
walter mitty's Avatar
Default Volvo S80 2.0T Oil leak?
Hi
I have 2000 s80 2.0 T and i have a fairly serious oil leak when the engine is hot. it is coming from the back centre of the engine. it is hitting the driveshaft and spreading it everywhere and i cant pin point it. i cant replicate the problem when the car is not driving. anyone any ideas on what it could be. its doesnt seem to be the turbo or the oil return pipe from the turbo. help
Old Sep 4, 2010 | 01:52 PM
Any help please. Can't seam to find the leak. Just keeps happening after driving the car.
Old Sep 4, 2010 | 02:23 PM
Old Sep 4, 2010 | 08:46 PM
SVTfocusO3's Avatar
You mean 2.9t?
Back center, by the firewall?
any pics.?
Old Sep 5, 2010 | 04:09 AM
No it's a 2.0T. It's an Irish car. It's spraying against the firewall it's a big mess. Will try and get photos up but very unclear to the eye so trying to find what to look for.
Thanks
Old Sep 5, 2010 | 06:27 AM
I would check the oil return line o-ring in the block.
Old Sep 5, 2010 | 08:22 AM
537playing's Avatar
Others have posted that a plug on their engine block might have popped out. Take a small mirror and see if you can find an opening. If this is the problem, tap in a new plug.
Old Sep 5, 2010 | 04:42 PM
It's not the return piPe o ring as that's what I checked first. I'm getting it put up on ramps again on Tuesday. Any idea where one of these bungs could be located. Thanks for the responses guys.
Old Sep 5, 2010 | 04:49 PM
What 537 was referring to only applies to Non turbo models.
Old Sep 6, 2010 | 08:00 AM
So back to Square one. Anyone else any ideas on what to look for
Old Sep 6, 2010 | 08:32 AM
Make sure there is not a crack in the oil feed line.
Old Sep 8, 2010 | 11:06 AM
will check this and let you know how i get on
Old Sep 14, 2010 | 06:41 PM
My bad. It was the wrong o ring fitted so replaced and think I'm sorted. Thanks for replys
s80turbo
Nov 24, 2010 07:55 PM
s80turbo
Jun 5, 2010 12:05 AM
ROBLU540
Feb 20, 2009 07:59 PM
draco3
Oct 31, 2008 07:16 AM
witstaffy
Jul 25, 2005 09:31 PM
