Won't Fire. "Immobilizer"
Kent Johnson (05-09-2021)
Do you know if you have spark? Does the sun roof open and close? If not then it may be the siren. Mine was full of water and corroded. I think I just unplugged it and the car started, but I may be wrong about that. If it is a security issue with the siren the sun roof won't work. Hope this helps.
Another strange issue I had was with the battery to the starter. I put a 2 foot cable from the starter to the fuse box in front of the engine and the car starts much more reliably. I can't tell you why, but it was two years finding that solution. The battery in the trunk appears to be that problem.
Jerry Balch
1998-2000 model year XC70
02-15-2014 11:51 PM
