Helpful Information - "How To" DIY Repairs - For 960 and S90's from 1994 - 1998 - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 02-19-2011, 11:25 AM
Default Helpful Information - "How To" DIY Repairs - For 960 and S90's from 1994 - 1998
This is a list of common problem/repairs for the 960 / S90. If you want a link added here, please search the thread or instructions and PM me the link so I can add it. Video instructions are highlighted in orange.
Door Panel Removal:
Door Panel Removal Instructions for Volvo 960
Climate Control Repairs:
http://volvoforums.com/forum/volvo-s...ion-fix-78676/
Electrical Issues After Start, Multiple, Bad Ignition Switch: VIDEO
major electrical issues.
Head Gasket Issue, Suspected:
960 Head gasket issues?
Instrument Panel Removal:
Instrument panel removal instructions on a Volvo 960
Parking Light and Turn Signal Problems:
Problems with lights - left reverse light always on... - Volvo Forums - Volvo Enthusiasts Forum
Power Seat Movement Repair:
http://volvoforums.com/forum/volvo-s...k-video-80451/ Video
Radiator removal / installation:
http://volvoforums.com/forum/volvo-s...70/#post406262 - Video
Shift Lock Repair (gear shifter will not move out of park):
Shift lock repair instructions for a Volvo 960
Sunroof Leak Repair:
Sunroof leak repair instructions on a Volvo 960
Timing Belt Replacement, printed & video:
Volvo 960, S90, V90 Timing Belt Replacement - Video
Old 07-03-2011, 09:03 AM
Default S90 power seat
Had the problem of one side moving and the other not. Great hint from a member advising to shorten the plastic sheath. My solution was to remove the cable. I did it the hard way by removing the seat, placing it on a stand to ease access, had to remove the gear drive to get the cable out. Separated the sheath from square drive. With a drill slightly smaller than the i. d. of the metal coupling, slowly removed the plastic to the four tiny cleats. Separated the couple from the plastic. Inserted the butt end of the bit into the small end of the couple and forced the gripping cleats out to the point where the shortened sheath would re-insert. Used a small punch to re-grip the cleats into the sheath. Insert the drive cable and assembled the mechanism. Works great so far. Thanks to the member who put me on track.
Old 07-03-2011, 08:17 PM
I repaired one seat the 2 hour method as well. Then I figured out the 30 minute method and decided to share it.
Old 01-30-2012, 01:02 PM
Smile S-90 driver's door lock repair
How do you get at the inside of the door to fix the electric lock? This Swedish built S-90 is built like a MRAP! Is there a SIPS unit in the door? I have the inside panel off but need tiny hands to get at the inside. Any suggestions? (No, my wife won't help) Thanks.
Old 01-30-2012, 09:31 PM
It's near impossible. You have to pull the bolts out of the door and remove the latch that way. No the door doesn't have SIPS, the seats do.
Old 01-01-2015, 10:33 PM
Do you have instructions on how to take out and replace a starter on a 1998 S90?
Becky
Thread Thread Starter Forum Replies Last Post
Hot Topics - Helpful Information - "How To" DIY Repairs JimKW Volvo 850 10 08-29-2016 06:45 PM
Important / Helpful Information - How To "DIY" Repairs rspi Volvo S70 4 07-08-2013 10:33 PM
Helpful Information - DIY Instructions - Old Stickies... rspi Volvo V70 0 06-06-2011 05:16 PM
Helpful Advice Needed! achase215 General Volvo Chat 1 10-04-2010 12:26 PM
DIY repairs vs. paying a shop MarkMc Volvo 850 8 08-22-2008 05:52 PM
Tags
1998, 960, diy, door, electric, panel, park, power, remove, repair, s90, seat, seats, shifter, transmission, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
