P0412 Secondary Air Injection: Valve A failure. - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 09-28-2010, 12:23 AM
Default P0412 Secondary Air Injection: Valve A failure.
Hey guys I've just finished some maintenance and had this code spring up when I started the car. I was messing around with the air filter and the piping for the AIR so I was just wondering where this valve was and what would cause the failure.
Old 09-28-2010, 09:50 PM
Probably a vacuum hose cracked, torn, loose.
Old 10-01-2010, 10:21 AM
Hmm...I was messing with some hoses when I was doing the A/C. Is this Valve A the valve on the passenger side AIR? Trying to track which hoses I should check and the Chilton's Manual is none too helpful.
Old 10-04-2010, 11:53 PM
I believe I actually mislabeled this one. It is a circuit malfunction for the Valve A on the AIR. Did something get unplugged?
Thread Thread Starter Forum Replies Last Post
Secondary Air Injection System Problem Air Defender Volvo S70 2 07-21-2011 12:23 AM
Air Control Valve (Idle Air Stabilizer Valve) Rakam Volvo 240, 740 & 940 4 05-27-2011 09:03 PM
Two DTC's P0412 and P0740 I8ASaleen Volvo S90 & V90 2 01-20-2011 03:22 PM
960 volvo secondary air injection question bigdummy Volvo 260, 760 & 960 1 08-01-2009 03:18 PM
p0410 Secondary Air Injection Fault jrw Volvo 260, 760 & 960 5 11-19-2005 09:13 PM
Tags
850, air, code, filter, induction, injection, intake, malfunction, p0412, s70, s90, secondary, seconddary, system, valve, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
