1997 V40 ABS / SPEEDOMETER problem
Old Jan 20, 2008 | 12:10 PM
golgiking's Avatar
Default 1997 V40 ABS / SPEEDOMETER problem
Hello - I have recently noticed that my ABS warning light has been coming on intermittently and that when it is on the speedometer stops working too (sits at zero). Problem has become more noticeable over the last few days (i.e. warning light on more often and for longer periods).
ABS module could be worn out (the car has done 157000 miles) or should I consider a worn sensor - if so which sensor(s) influence the speedometer ?
any feedback greatly appreciated !
Old Jan 20, 2008 | 01:15 PM
billofdurham's Avatar
Default RE: 1997 V40 ABS / SPEEDOMETER problem
The ABS has a self diagnostic capability and fault codes can be read using a suitable code reader. This would pinpoint the exact cause of your problem.
Old May 17, 2012 | 12:37 AM
Elchopperfreak's Avatar
Abs module is slowly dying..
Old May 29, 2012 | 08:56 PM
frtdrmrose7's Avatar
Check the front right wheel sensor
Old Mar 8, 2013 | 08:46 AM
Lovettdc's Avatar
I had the same problem and went to the junkyard and found an ABS module out of a 01 s40 and when I put it in all my lights and problems went away. I have a 2000 v40. I am also planning on fusing my old module for either a backup or to sell.
1981volvoguy
Jan 6, 2011 08:53 PM
JasonD
Mar 31, 2010 10:40 PM
vulvamom
Jun 25, 2009 06:50 PM
darimik
Jun 24, 2008 08:03 PM
paulh
Jan 30, 2008 08:22 PM
