2000 Volvo V40 issues.
I bought this car off a friend for $800 only, ran fine only issue was a misfire on cylinder 1 and hard start due to fuel pressure regulator. Got all new spark plugs and the misfire on cylinder 1 went away along with the check engine light. Decided I wanted to clean the air filter box to try and improve starting so I asked my friend with me to remove the hose and pointed to it (I know he has some car background so I trust.) I go to get stuff out of the hatch when he says green liquid came out of the hose so he put it back quickly. Came over and noticed antifreeze on my engine and fuel injector plugs and the coolant tank was slightly low. I topped off the tank to the max line and whipped off as much antifreeze as i could from the engine cover and fuel injector plugs. Started the car and it sputtered more than usual as the check engine light came on, I read the code and it said misfire cylinder 3. I also noticed a hissing sound near the PCV area that wasn't there before. Car is derivable just not registered, any suggestions?
Well now that is has warmed up somewhat here in Connecticut ive gotten back to the car, replaced the fuel injectors and fuel pressure regulator which solved the hard start and sputtering issue. I also discovered the spark plug and injector wires had some exposed wiring that was fixed with some electrical tape and a coil pack boot was cracked so put heat shrink tubing over the boot until I can buy a new one. So far no check engine light or rough running!
ddrewyor
01-08-2012 03:36 PM
Hannahlyn13
06-03-2011 12:23 PM
