Shift indicator light? - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 11-21-2008, 04:44 PM
Default Shift indicator light?
Is there suppose to be an indicator light for the automatic transmission shifter? At night I can't see what gear I'm in without turning on the interior light. I bought the car used and it came this way. If there is a light, how do you replace the bulb? Thank you,
Jim
Old 11-21-2008, 05:29 PM
Default RE: Shift indicator light?
There should be a light.
Remove the side panel on the driver's side of the centre console. There is one screw towards the front, at the top of the panel. Pull the panel out with a twisting action then pull it backwards. Remove the tie strap and clips from the heater unit. Remove the bulb holder and bulb.
Reinstall in the reverse order.
Old 11-24-2008, 06:58 PM
Thank you for the reply. I will try to look at it soon and see if I can get the side panel off.
Jim
Old 08-28-2010, 12:39 PM
Did it Work? can you explain me how to do it? I have the same problem on my 2002 S40
Thread Thread Starter Forum Replies Last Post
Shift indicator light jsmoline Volvo 260, 760 & 960 4 05-15-2010 08:14 PM
Shift gear indicator light how to change? jasongood Volvo 850 5 01-08-2009 09:48 AM
Shift light indicator wont work. 86 GLE colgate41 Volvo 240, 740 & 940 0 07-31-2008 03:04 PM
Shift indicator bulb? s70familoy Volvo S70 0 02-21-2006 02:43 AM
1989 740 gl shift indicator light daisyifyoudo Volvo 240, 740 & 940 2 10-29-2005 06:19 PM
Tags
2000, 90, automatic, bulb, indicator, light, replace, s70, shift, shifter, transmision, transmission, upshift, v40, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
