Shift indicator light?
Old 11-21-2008, 03:44 PM
jwscott's Avatar
Default Shift indicator light?
Is there suppose to be an indicator light for the automatic transmission shifter? At night I can't see what gear I'm in without turning on the interior light. I bought the car used and it came this way. If there is a light, how do you replace the bulb? Thank you,
Jim
Old 11-21-2008, 04:29 PM
billofdurham's Avatar
Default RE: Shift indicator light?
There should be a light.
Remove the side panel on the driver's side of the centre console. There is one screw towards the front, at the top of the panel. Pull the panel out with a twisting action then pull it backwards. Remove the tie strap and clips from the heater unit. Remove the bulb holder and bulb.
Reinstall in the reverse order.
Old 11-24-2008, 05:58 PM
jwscott's Avatar
Thank you for the reply. I will try to look at it soon and see if I can get the side panel off.
Jim
Old 08-28-2010, 11:39 AM
adan_j88's Avatar
Did it Work? can you explain me how to do it? I have the same problem on my 2002 S40
jsmoline
05-15-2010 07:14 PM
jasongood
01-08-2009 08:48 AM
colgate41
07-31-2008 02:04 PM
s70familoy
02-21-2006 01:43 AM
daisyifyoudo
10-29-2005 05:19 PM
Quick Reply: Shift indicator light?
