Volvo V40 2001 Timing belt installation!!!???? - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 10-27-2007, 12:29 PM
Default Volvo V40 2001 Timing belt installation!!!????
Hi everybody ,
Like a first timer I will need your help . My V40 2001 1.9T needs the timing belt to be changed . But I don't have the positions gage . If someone have a picture of how to instal it or explain me the positions it will be apreciate . Thank u
Old 10-27-2007, 01:23 PM
Default RE: Volvo V40 2001 Timing belt installation!!!????
The top cover is the timing marks and the others are on the pulleys.
http://www.babcox.com/editorial/ic/ic60326.htm
This site might help a little.
Old 10-27-2007, 06:08 PM
Thank you very much ... The timing belt is already cracked and when i,m on Drive(automatic transmission) at a stop sign the engine die andwhen i restart the car it start rightaway ...i changed the alternator , and it still does it... than i realized that the timing is cracked and may skip on gears . Hope is that .... Thanx again cause even Volvo could not find the problem .....VOLVO CANADA lol
Old 11-07-2007, 11:19 PM
timing belt rarely skips in S40/V40 with the 1.9T but replacing timing belt will need u jack up engine and remove the mount on side of engine also r/f tire have to come off. mostly when not idling is IAC motor. hope this help
Thread Thread Starter Forum Replies Last Post
2002 Volvo V40 Timing belt question andoras1977 New Members Area 2 02-05-2014 03:50 AM
Improper Timing Belt Installation? NHVolvoMan General Volvo Chat 2 09-22-2011 01:57 PM
Any Tips or tricks for v40 timing belt and vvt pulley replacement? russellsv40 Volvo V40 0 06-02-2011 01:02 PM
Timing Belt Installation question yank50 Volvo S80 3 03-01-2009 09:59 PM
Timing belt installation problem '00 S70 Johnboy Volvo S70 1 12-11-2008 08:35 AM
Tags
19t, 2000, 2001, belt, changed, instalation, installation, instructions, marks, replacement, s40, timing, v40, volvo, vovlo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
