1997 V70 R AWD Prop shaft problem
Hi there.
I have a 1997 V70 R AWD with a knocking prop shaft. The universal joint is knocking on the underside of the car when I turn a corner (15mph or less).
Does anyone know whether it is possible to remove the prop shaft and still run the car while I wait for the parts to repair this arrive?
Thanks in advance, Lee
RE: 1997 V70 R AWD Prop shaft problem
Yeah, and unless you live in the mountains or in the snowbelt you may want to save yourself some $$$ and just leave the drive shaft out and turn it into a FWD 'R'. BTW, unless you're in Europe (your profile doesn't indicate) there's no such thing as a '97 V70R...
Thanks for getting back to me. I'll remove it this week then, the banging is annoying.[:@]
"unless you're in Europe (your profile doesn't indicate) there's no such thing as a '97 V70R..."
I'm from Scotland so its defo a 1997 model. My V5 clearly says V70 R AWD 1st reg 26th Sept 1997.
I HPi'd it before I bought it too.
