Ticking Relay
Old 01-13-2007, 01:21 PM
Wounded Horse's Avatar
Default Ticking Relay
In the space behind the LH rear lamp cluster on my 97 T5 estate, there is a cicuit board - long and narrow - that has the legend RYDER on it. It ticks every 2 seconds when the engine is running. Is this the fuel pump relay? It's a bit irritating.
Old 01-13-2007, 01:36 PM
Default RE: Ticking Relay
Would you be able to post a pic of it?
Old 01-13-2007, 06:21 PM
How do I post a pic? Do I have to host the pic somewhere and link to it with [img] link /[img]
The device is about 4 inches long and 3/4 inches wide with three wires at one end and two at the other with I think 2 small relays on a mica circuit board containing resistors and the like. It has an unclippablee black plastic cover. To get at it I removed the carpet rectangle in front of the light cluster and parted some cables and eased it out on its own cables. Says Ryder on the plastic cover. I should also say that it doesn't always make the noise but when it does it's annoying. Thanks.
Old 01-13-2007, 07:54 PM
If you click post reply and not use the fast reply you shold be able to upload it from your PC.
If not then you can host it and use the img links.
Old 01-14-2007, 11:06 AM
Pis as requested. Thanks
[IMG]local://upfiles/8340/893169C9842043B98A3F2104A9A27130.jpg[/IMG]
[IMG]local://upfiles/8340/ACC8DBAEF3A24E87BCC42448718A66B8.jpg[/IMG]
Old 01-15-2007, 08:46 PM
That looks kind of like it is a adapter for a trailer hitch wiring.
It is not factory.
Captain Zov
06-18-2021 12:01 PM
sleech
01-25-2020 05:07 PM
redbottle
12-29-2009 11:25 PM
dads 740 turbo
10-24-2008 06:54 PM
plaganir
03-10-2008 05:45 PM
Quick Reply: Ticking Relay
