2001 V70 climate control blower motor issue - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 06-06-2013, 02:55 PM
Default 2001 V70 climate control blower motor issue
Hello,
I am hoping someone may be able to shed some light on an issue that has just sprung up on my '01 V70 T5. The issue does not seem to be the CCM, because all lights function and it has power. The blower motor just cut out on me. No air flow at all. The A/C does work, for when the car is moving, some cold air is forced from the vents. The motor quit flat out yesterday, after no odd sounds, squalling or any of the normal indicators that a DC motor usually gives prior to failure. Then, mysteriously, it started working again, but only for a short time, then failed again. As stated, all lights on the CCM are functioning, including the segmented LEDs that surround the speed control ****. Could the blower motor be shot? Is this indicative of a CCM problem? It is an dual zone automatic CCM. Of course, this had to happen just as the hot and humid weather of the summer is upon us in NC. I have read the horror stories of the $1300.00 CCM replacements at the dealership and the outrageous amount that my local Volvo dealer wants just for a simple diagnostic. I have read that there is a blower motor resistor. Could this be the problem? Some insight would be greatly appreciated. My friend owns a repair shop, but his Volvo knowledge is limited to what he finds on these types of forums. I have spent the afternoon combing through the threads, but I have not found anything specific to this particular problem. I love the car, but refuse to pay more for a repair than the car is actually worth to me. Thanks.
Old 06-18-2013, 07:46 PM
Default ECC blower problem 1998 V70
Fan motor became erratic changing speeds randomly, then quit altogether.
Removed fan motor & jumpered to 12 volts motor started then quit. Thumped motor with hand & it started & then quit again. Voltmeter showed 12.6 volts at motor when it was not running. Replaced motor & all is fine.
To access motor , remove glove box & knee bolster -1998 only, glove box & under tray on later models.
Thread Thread Starter Forum Replies Last Post
98 V70 XC Electric Climate Control issue SuperDayv 1998-2000 model year V70 0 11-12-2014 02:52 PM
2001 V70 Fan Blower Motor Replacement worldbound4now Volvo V70 6 01-04-2012 04:10 PM
Climate control problem: Blower stuck on, CC panel not working mhphoto Volvo 850 6 04-27-2011 07:55 PM
Climate Control Blower turns on when car is off alexxc70 Volvo V70 2 07-28-2010 12:14 PM
No Climate Control/Cruise Control??? jfikentscher Volvo 850 4 05-31-2006 10:58 PM
Tags
2001, blower, climate, control, fan, issues, location, motor, replacement, resister, running, speed, v70, volvo, vovlo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
