Crank pulley seal replacement
Old 10-30-2017, 01:03 PM
Richard T's Avatar
Default Crank pulley seal replacement
Hi folks.
I have a 2002 v70 xc with a 2.4 turbo
I'm hoping someone can help advise me on this issue.
This isn't a job that I want to attempt myself considering the timing belt is a factor. So I was wondering if one of you guys can tell me what kind of time frame is needed to do this repair so I don't get screwed by whatever service place I go to.
Thanks in advance.
Richard
Old 10-30-2017, 06:57 PM
My guess is just to do the timing belt is about 2 hours and if you add an hour for removing the pulley and replacing the seal, you're somewhere at 3+ hours. Depending on when you last did the timing belt, you will want to replace the belt and tensioner and check the idlers. The VVT set up adds some complexity to the timing belt reinstall vs pre-2000 engines...
Old 10-31-2017, 11:15 AM
Richard T's Avatar
Thanks Mt.
Gives me some idea.
Much appreciated.
Richard
joedogg
01-15-2016 03:16 PM
ZaphodBblbrux
07-02-2012 09:54 PM
guest01
11-05-2011 10:11 PM
MikeySq
03-30-2011 09:22 PM
whyflygti
10-04-2005 01:23 AM
Quick Reply: Crank pulley seal replacement
