98 v70 fuel pump - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 07-02-2011, 02:28 PM
Default 98 v70 fuel pump
I am trying to figure out whether my v70 turbo has one or two fuel pumps. I hear it turn on in the passenger side rear seat area. The problem is ,is that it does not come on every time. I just replaced the relay ,the big red one but that didn't do anything. So now I'm trying to figure out if the fuel pump is faulty and which one is it if there are two.I'm assuming that there is one in the tank and another somewhere else. Is there some simple test that I can do before dropping the tank.Thanks for any suggestions.
Old 07-03-2011, 12:48 AM
gdog's Avatar
I am quite sure your V70 FWD is same as 850 in that it has an access cover to get to the fuel pump. There's only the one pump in the tank. Only on the AWD models do you have to drop the tank to get to the fuel pump.
Did you replace the fuel pump relay (i don't know what the big red one is..)?
To verify it's the pump, you can pop the access cover off, and next time it doesn't start (or dies), then rap on the top of the pump assembly. If it starts working, even briefly, then it's time for a new pump...
Old 07-07-2011, 08:42 PM
Have 1998 volvo v70 wagon which starts but dies after about 30sec or when step on gas pedal, I replace mass airflow sensor, engine coolant temperature sensor, and trottle control valve, neither of which solved the problem, what other causes should I look for. Thank you!
Old 07-08-2011, 01:45 PM
Quote:
only one pump, but it has a tube to go to the other side. check and see if there is power to the fuel pump when it doesn't work. if you got power there then the pump is out. i would do the fuel filter too.
you can access it thru the inside, just behide the middle seats. 4 10mm nuts and there it is.
Crush
Old 08-03-2011, 10:37 AM
Hi peeps, just wondering I have a 1998 volvo v70 turbo AWD and the fuel pump which is situated inside the tank has gone, and unfortunately I have to drop the tank to put the new pump in. I took off the plastic cover underneath the car and the metal band which seems to be holding the tank in but i cant see any other means of it coming off, obviously thinking it was going to be a doddle how does the fuel tank come out? whats the process? Id appreciate any suggestions
Thread Thread Starter Forum Replies Last Post
No fuel from pump or at pump in tank rphud Volvo S60 & V60 2 09-27-2014 07:06 PM
Volvo 850 random stalling and hard to start. Testing Fuel Pump and Fuel Pump Relay 1995Volvo850 Volvo 850 13 08-05-2013 12:19 PM
Fuel Pump/Fuel Pump Relay spidersilva Volvo 850 8 08-17-2011 08:23 PM
88 240dl fuel pump not getting power after water pump explodes... scrap88 Volvo 240, 740 & 940 6 04-07-2010 10:23 PM
'90 240: fuel pump working, pump relay OK. Regulator? montysano Volvo 240, 740 & 940 2 09-09-2008 12:52 PM
Tags
1998, 98, access, code, find, fuel, fwd, pumb, pump, replace, tanks, test, v70, volvo, wagon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
