98 V70 T5 ce lite P0442 code
Old 05-07-2011, 04:41 PM
rosko's Avatar
Default 98 V70 T5 ce lite P0442 code
Hi,
P0442 is a small evap leak issue, I repaired the J-tube under the car, but the lite is still commanded on. Any other suggestions on how to find this small evap leak?
Thanks
Ross
Old 05-07-2011, 06:56 PM
tony1963's Avatar
Did you clear the code after you replaced the line? If not, it will reset in a few start/stop cycles.
Old 05-20-2011, 11:02 AM
tplman's Avatar
Default code P0442
I have the same problem w/that code. Have replaced the J hose, runs until it rains, sputters & runs rough or engine dies. Will not restart! Let it sit for 2 + hrs. & it starts up again & runs fine. Any suggestions??
jelwynn
04-18-2024 02:35 AM
hu5ker555
05-05-2011 07:12 AM
Frog
10-30-2010 08:16 PM
nattyderek
05-10-2010 09:04 AM
volvoluv
01-07-2010 10:38 AM
Quick Reply: 98 V70 T5 ce lite P0442 code
