99 XC70 key keeps turning around in ignition
Old 08-29-2009, 02:28 PM
volvorecycle's Avatar
Default 99 XC70 key keeps turning around in ignition
the problem is this 99 xc70 key will keep turing around in the ignition assembly.
i know it needs another assembly, and volvo says it must be brand new.
well i have a used one actually only 2 weeks old in a 99 s70 t5 that then got in an accident. i have the ignition assembly, immobilizer ring, and module that i installed in the xc and the car will not start. so this is telling me that it does indeed have to be a new assembly and that volvo then mates it to the car?
has anyone ever put a used one in and did it work?
Old 08-30-2009, 07:21 AM
Used ones will not work on 99 and up cars. It is because the keys are programmed to the car. If you order one that matches the original key code and reinstall the original module and then install the new lock assembly it should start right up.
Old 09-01-2009, 06:12 PM
i figured out a solution so I can use the used one.
install the used one and it will tun the ignition switch and the shift release, but wont sense the key and will not turn over.
but if i tie up the old one under the dash somewhere keeping the key in the ignition part and keep the key sensor ring plugged in it will start up. HA
but i am going to try to get the dealer to reprogram the used keys to the vehicle so i do not have to use this method. i will let you know what happens
Old 09-01-2009, 06:48 PM
mkc70's Avatar
Do you still have the other instrument cluster?
Daniel Sendelbach
01-11-2014 07:29 PM
volvolini
12-02-2009 06:38 AM
ciao-rich
06-13-2008 05:01 PM
Quick Reply: 99 XC70 key keeps turning around in ignition
