07-16-2008, 06:21 AM
boost pressure
hi all what pressure should i see from a lpt v70 awd when given the berrys?
cheers rob
07-16-2008, 07:27 AM
1999 Volvo S70
RE: boost pressure
5-7 PSI is normal for stock boost on an LPT.
__________________
CHECK THIS LINK NOW
07-16-2008, 07:34 AM
RE: boost pressure
oops think i need a lower scale boost gauge then!
the on ei just got goes to 30 psi!!! hahahaha
rob
07-16-2008, 08:10 AM
1999 Volvo S70
RE: boost pressure
Your fine. You don't need to down grade.
I have an LPT and I have a 25 In Hg / 25 PSI gauge. But I have an ECU upgrade so I am pushing 15PSI right now.
__________________
CHECK THIS LINK NOW
07-16-2008, 02:53 PM
RE: boost pressure
s70 your pushing 15 psi with an lpt?
__________________
.............. V-O-L-V-O .................
'98 s70 GLT with mods that make it fast
07-16-2008, 06:26 PM
1999 Volvo S70
RE: boost pressure
Quote:
ORIGINAL: samadkins29
Yes and that is the highest you want to push on an LPT period.
__________________
CHECK THIS LINK NOW
07-17-2008, 02:36 AM
RE: boost pressure
so would it be poss to wind a stock turbo open to say 10-11 psi? with no other mods? and safely?
if not can i put a normal t5 turbo on my engine with no reliability issues? and what pressure would a stock t5 turbo give?
rob
07-17-2008, 07:42 AM
1999 Volvo S70
RE: boost pressure
1. You can run 15 PSI on your OEM turbo with no problems. Now if that turbo is going bad or is already in bad shape then yes there can be problems. 10-12 PSI is a good boost in pressure and a nice noticable difference from 5-7 PSI. And it is safe if you go with an ECU upgrade.
2. You can put a T5 turbo on your car. But it isn't going to boot anymore pressure then what yours is now. Because your ECU is controlling the boost pressure. But a T5 turbo can handle more pressure better then your LPT turbo can.
__________________
CHECK THIS LINK NOW
07-17-2008, 08:29 AM
RE: boost pressure
"Standard" ECU chip will be around 12 lbs and is very nice and verynoticable
__________________
2000 V70R Silver 36,000 miles!!!!! Lifetime keeper
2000 V70R Black 109,500 miles, (Wife's)
2007 XC70 White and LOADED, new DD, 114K but looks new
Email: jrl1194(at)aol(dot)com
07-17-2008, 06:22 PM
RE: boost pressure
Quote:
ORIGINAL: JRL
sorry bud but what do you mean by standard ecu chip?
rob
Tags
1999, 2000, 98, boost, ecu, level, lpt, pressure, psi, stock, t5, upgrade, v70, volvo, xc90  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
