Brake disk size? - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 08-19-2009, 01:28 AM
Default Brake disk size?
Im shopping for a replacement rotors for my 2001 V70 T5
different sites give me different sizes for the front rotors
is it 12" or 11.3"
its either 305 millimeters or 286 millimeters
im confused, also whats the size of rears and what are the best pads to use?
Old 08-19-2009, 05:29 AM
Default brake rotors
my (2) 2001 T5s
vin yv1sw53k91207651 and yv1sw53k912041357
both have 12" rotors
If yours in in between almost guarantee it will have 12" rotors
that said, I'd measure them it takes 5 mins to jack up the car and rip a wheel off.
Its a pain with these cars, thats why you cannot buy anything from a dealer without a VIN..
Cheers Karl
Old 08-20-2009, 06:25 AM
Default pad and rotor change
did mine today, rotors were $89 AUD each and pads were $36.
pads are better than OEM and I notcied min thickness on rotors is 25mm not 28 per the factory discs so should get three set of pads to these as opposed to two from the factory ones.
Easiest pad and rotor change going, just need a 15mm socket, 1/2" drive ratchet and a 7mm allen key (available at almost any hardware store)
Karl
Old 08-25-2009, 12:18 AM
thats coming in handy
i went to tirerack.com and found the rotors pretty cheap and they are brembos, and akebono pads
should i go with that or should i go for some flash by getting cross-drilled and slotted rotors from Royalty Rotors and forgoing their pads (too cheap, im scared to buy them) and just getting akebono pads from TireRack.com?
Old 08-26-2009, 07:33 PM
i8av8's Avatar
i'm going with ipd's set-up whenever i get my catalog from them.
Old 08-26-2009, 08:16 PM
Dude, if I were swimming in $$$ then fine, but IDP's setup, while nice is very expensive. As most of their stuff.
Not to say its not worth it, it is. Love the quality but man oh man are they pricey
Old 08-26-2009, 08:41 PM
i8av8's Avatar
yeah, i know. but i just came across some cha-ching and i don't mind spending that. besides, i need to know i will be able to stop with all the mods i plan on doing. not that i wouldn't be able to stop if i got something a little bit cheaper. i also want to make sure my brakes look good. to each their own, i guess?
you'll find the right set-up. just don't settle for something that you might regret later.
Thread Thread Starter Forum Replies Last Post
thickness disk brake g.nardo Volvo V70 2 10-24-2011 02:28 AM
Disk brake min's CaliS80T6 Volvo S80 1 06-22-2006 12:37 AM
Disk Brake service Musicjunkie2k Volvo S60 & V60 3 01-09-2005 08:27 PM
Removal of Disk for brake job rcoll Volvo S70 5 12-16-2004 12:56 AM
Removal of Disk for brake job rcoll New Members Area 0 12-14-2004 03:56 PM
Tags
2001, 2009, brake, diameter, disc, discs, find, rotor, rotors, size, sizes, t5, v70, vin, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
