CEM/REM on V70 - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 01-17-2009, 03:06 PM
Default CEM/REM on V70
Evening All.
Im new to this site so here goes. I got a volvo V70 my back passanger doors,tail gate doorand fuel hatch are dead lockedplus my rear reversing lights, fuel gauge & rear window wiper are not working. Took the car to main dealer today they said its my CEM &REM are at fault which is going to cost £1000 plus. Is there anyway i can get it fixedcheaper.Also cananybody tell me where they can be found on the car, It is a 51 reg
Cheers Mercury.
Old 01-17-2009, 08:53 PM
Default RE: CEM/REM on V70
If they are indeed bad then no there is no cheaper way.
But I would check all the battery terminal connections and connections to the REM. Then REM(fuse panel) is mounted under the panel by the L/R taillight.
The CEM is under the dash on the L/S of the car. You will see a bunch of relays in it.
I have seen bad connections cause this problem quite a few times. It is usually at the battery and cables.
Old 01-19-2009, 08:50 AM
Welcome aboard. Listen to tech, tech is good, tech is wise.
Thread Thread Starter Forum Replies Last Post
Where to send a REM for repair? Geoff813 Volvo S60 & V60 5 06-01-2014 07:32 AM
CEM Removal & CEM Instalation in an 04 XC70 JenniferXC70 2001-2013 model year XC70 4 08-20-2013 11:26 PM
REM not working, going crazy when we connect something to the towsocket Raniz 1998-2000 model year V70 0 07-05-2013 06:35 AM
S60 rem deeno77 Volvo S60 & V60 8 04-18-2013 08:11 AM
Replace REM tzracer Volvo S60 & V60 3 11-29-2007 07:09 PM
Tags
02, 2007, 70, box, cem, cost, drivrem, fuse, fuses, multirem, rem, s60, v70, volvo, xc70
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
