Codes P0410 and P0172
Old 04-02-2006, 10:30 AM
JimKW's Avatar
Default Codes P0410 and P0172
I keep getting these two codes on my 98 V70. I have cleaned the throttle body and replaced the MAF Sensor. From where I look for codes it says the following:
P0172 - System Too Rich
P0410 - Secondary Air Injection System Malfunction
The car runs perfectly fine, it just always has the CEL on and I get these codes constantly. It's been doing it for quite some time. I rarely drive the car and my wife just ignores the CEL and Service Light.
Old 04-03-2006, 08:35 PM
Default RE: Codes P0410 and P0172
Sounds like you have a bad Air pump. Do you hear the Air pump in the morning?
They usually fill with water and short out.
Old 04-03-2006, 09:31 PM
JimKW's Avatar
Not sure what you mean by hear the air pump? Where should I listen and what am I listening for?
Old 04-03-2006, 09:41 PM
First thing in the morning after it has been sitting all night. Start it up and listen for a Hairdryer noise under the L/F.
It is mounted to the body under the battery tray. It is not the cuise motor but lower than that.
The Air guide will have to be off to see it.
Old 04-03-2006, 09:49 PM
JimKW's Avatar
The car has not been run for probably eight hours and I went out and started it. I don't think I heard anything down below the air filter box. There is about a 1 inch diameter hose coming out the front of the air filter box and it goes down in front of the box. Is that going to the air pump?
Old 04-03-2006, 10:01 PM
Yes it is.
The Air pump only comes on when the car is totally cold and it only runs about 1 minute and then shuts off.
Old 04-20-2006, 11:48 PM
Update:P-0172= Volvo code 231/232 Long term fuel trim Idling Upper limit.
Possible sources: Mass flow sensor bad,Low fuel pressure,Air leak,Faulty Pulsation Dampner,Faulty sensor signals.
Did you also have a P0440?
If so then you need to check the Evap system as well.
I would start looking for a Vaccum leak first. TipCheck the end of the intake by the Power steering pump and make sure the Elbow doesn't have a hole in it. That is if you have one.
Then I would check fuel pressure. Then make the Mass flow the last item.
Hope this helps.
Old 06-05-2006, 01:45 PM
JimKW's Avatar
I only get the P0410 not P0440 and I don't get it all the time. It gets P0172 all the time though I was just getting ready to replace the Air Pump. Should I replace the Check Valve too? Volvospeed.com Bay 13 say to change the check valve at the same time as the air pump, but I'm not sure it's necessary.
My wife is saying the car is running real rough at times and feels like it about to stall out then it will run ok. I drove it for 14 hours last weekend and never felt this so it must have just started happening. I was going to change the Fuel Filter since it has not been changed at least since I bought the car. It has 108,000 miles on it and I got it at 72,000. Figure it can't hurt to change it and from what she said it sound like a fuel problem.
Anything else I should check?
Old 06-05-2006, 09:08 PM
Fuel filter sounds good.
The valve is easy to check/remove. 2 screws hold it on then you need to add Vaccum and make sure it moves.
If the Valve moves it is good.
Not sure if that will cause the Long term fuel trim code as well.
Have you checked for vaccum leaks good yet?
Old 06-05-2006, 11:00 PM
rmmagow's Avatar
Hi Tech, are you talking about the valve with the flat top torwards the back side of the engine. Has a small line and two hoses coming off it? If I remove this valve, apply vacuum to the thing and the valve moves it is OK? Just replace the Air pump? I ask beacuse I have this job coming up and that valve is EXPENSIVE!!
Thanks.
Old 06-05-2006, 11:04 PM
Yes that one is it. You can also clean it out with Carb or Brake clean.
I would also reccomend replacing the Relay.
Old 06-06-2006, 04:13 PM
rmmagow's Avatar
The relay being the part towards the front of the car, off-center to the right side and directly in back of the radiator? Looks very easy to get at?
Maybe called a solenoid at some parts sites?
Thanks.
Old 06-06-2006, 09:08 PM
The Air pump plugs into the Relay.
Or might be mounted in the Main relay box under the hood.
rogwadd
03-27-2012 09:00 AM
pnhons
04-16-2011 02:35 PM
Svtfiveoh
08-21-2008 07:46 PM
timothysoconnell
09-05-2006 01:09 AM
Quick Reply: Codes P0410 and P0172
