Driver side front and rear carpet wet
Old 10-30-2016, 05:37 PM
qwertyjjj's Avatar
Default Driver side front and rear carpet wet
After 70mm of rain the other day I was left with an inch of water in both the front and rear driver side footwells.
The front has now dried out but the rear is still wet.
I checked the roof drains and poured a cup in the drain. Both sides show water coming out below the car but the left side is very slow. I tried attaching a tube and blowing and it seems kind of blocked.
I can't get a wire down it to clean it and when I took off the a frame cover, the drain pipe is hidden behind the metal so it cannot be accessed.
Any ideas how I can unblock this properly? Will drain cleaner work?
Someone said there may also be 2 back drains on the sunroof bit I cannot see them.
The spare wheel compartment is also dry so it seems like the tailgate is sealed.
banderson
10-26-2014 06:25 AM
iaincross
11-27-2010 10:59 PM
mspidare
05-23-2009 10:35 PM
jafargio
05-18-2009 09:15 AM
Volvo S 40
04-07-2009 08:04 PM
Quick Reply: Driver side front and rear carpet wet
